Want to Borrow: Engine Lift
I need to borrow an engine lift for a weekend, my motor is toast, 20qts of oil to drive 30 miles, i need to swap the old one back in. it wont take me longer then a day to do this, if anyone could help me out it would be much appreciated, ill throw you a couple bux for the trouble
As a fellow EP3 owner I can loan you my cherry picker…
You can rent one from that place on Lebanon Church road, like 50 bucks for two days IIRC.
you have a pm!
Just don’t use it while you’re high!
i have one… south hills
taylor rental curry hollow road. phone num is 653-7177 or 655-7177 but i think its the first.
but just go with the others from around here if you can
thanks for the help guys!
http://www.pittspeed.com/forums/showthread.php?t=46768
$10. Can’t beat that.
thanks for the heads up!
Wow what happ?? I hope u get it sorted out.
i bought an engine off eric at hybrid and i checked it out and it looked good, so i put in the car (almost bymyself i had a little helpw with the lift and random bits) then i fire it up, sounds good, i go to back down the drive and i notice two trails of oil, so back in the garage, and i pop the hood and jack it up then i notice there is oil dripping down my clutch all in my trans housing and from the front of the case. i have never heard of the main seals going bad on a kseries engine before but thats exactly what happened, they looked fine but they were toast… the motor that i had in there was the same engine i swapped in a k24a4 but my previous engine has a bad valve seal or ring because its smoking, so thats what im swapping back in then im building a k24a2 for boost
