i have a ceramic coated dc header on my car now. well me being a dumbass rocked the bottom of my header on various things, see picture below.
so i picked up this gsr ractive header from a fellow board member (<3 spandex). it needs some love but hey ill take it.
now heres my problem, my header has 3 bungs welded in for o2 sensors. the gsr only has only 2.
on my header= 2 on the top and 1 by the end that bolts up to the cat.
ractive gsr header=1 on top and one on the bottom.
any help is appreciated and if anyone on here can weld this for me, that would be sweet. im hoping someone from hybrid can chime in since i was going to bring to you guys, but i figured i would check here first.
now my ? is, would it be possible to have another bung welded in to another tube for my o2 sensor. another option is to splice my o2 sensors into 1 and use it as is, or just sell it and buy another one.
edit- i would also like to get a skidplate welded to this one to prevent it from getting fucked again.
ya it will fit, i would just fix the DC header. you can cut that section out weld a new section then a skid plate to that. it is much better then the ractive.
how many o2 sensors are you running? all you need is 1. buy plugs and plug up the unneeded bungs.
well i will worry about that after i get the new one on. its my dd right now until i get my truck back, but how do i get it to fit? splice the 2 or weld in a new thread for my 2nd os sensor?
im not sure, hybrid did the swap and all the bolt-ons too. i bought it like that. i might just splice the 2 into one and hopefully that will do the trick.
