Alright guys for some of you it’s coming up on that time for your cars to get parked. That means winter projects begin. We’ll be offering par pricing and we will be covering the customs/brokerage fees. All prices below are in CAD and are shipped to our shop located in Mississauga.
Clutches:
Z1 SR20DET Performance Clutch Kit $428 CAD shipped
The Z1 Motorsports SR20DET Performance Clutch Kit is engineered to give you the best compromise between clamping force, driveability, and light weight performance. This assembly provides approximately 80% increase in torque capacity and is properly suited for aggressive street use and moderate track use. The Carbon Kevlar material with its alloy backing matched to a performance pressure plate will provide smooth engagement and extended life. 500 mile break-in highly recommended with this set-up.
kit includes a performance pressure plate, a high torque sprung disc with antiburst steel backed Carbon Kevlar facings, all applicable bearings, and the appropriate alignment tool.
Z1 KA24DE and KA24E Performance Clutch Kit $349 CAD shipped
The Z1 Motorsports KA24 Performance Clutch Kit is engineered to give you the best compromise between clamping force, driveability, and light weight performance. This assembly provides approximately 80% increase in torque capacity and is properly suited for aggressive street use and moderate track use. The Carbon Kevlar material with its alloy backing matched to a performance pressure plate will provide smooth engagement and extended life. 500 mile break-in highly recommended with this set-up.
Z1 Ceramic 6 Puck Clutch Kit SR20DET $478 CAD shipped
The Z1 Motorsports SR20 6 Puck Clutch Kit is engineered to give you the best compromise between clamping force, driveability, and light weight performance.This assembly, available with a double spring, six rivet carriage is good for ease of gear transition with higher horsepower. This disc complimented by a performance pressure plate provides 250% increase in torque capacity.
The Z1 kit includes a performance pressure plate, a six puck high torque sprung disc with Ceramic buttons, all applicable bearings, and the appropriate alignment tool.
Z1 Ceramic 6 Puck Clutch Kit KA24DE and KA24E $399 CAD shipped
The Z1 Motorsports KA24 6 Puck Clutch Kit is engineered to give you the best compromise between clamping force, driveability, and light weight performance.This assembly, available with a double spring, six rivet carriage is good for ease of gear transition with higher horsepower. This disc complimented by a performance pressure plate provides 250% increase in torque capacity.
Z1 SR20DET Twin Plate Clutch Assembly $1358 CAD shipped
Z1 Motorsports provides the most economical racing clutch for the active sport compact enthusiast and is the preferred assembly for the professional racer. We currently offer our 4140 Forged Steel Flywheel with this unit to ensure durability in extreme racing conditions.
The Z1 Twin Disc delivers uncompromised reliability and performance. All assemblies are plug and play with no additional modifications required in the transmission. Guaranteed to provide simplicity in installation and inexpensive component repair and replacement.
Z1 KA24DE Twin Plate Clutch Assembly $1358 CAD shipped
Flywheels:
Z1 SR20DET Ultra Lightweight Steel Flywheel $378 CAD shipped
Z1 Motorsports SR20DET 4140 Forged Steel Ultra Light Weight Flywheel
The Z1 flywheel is precision machined to reduce rotating weight while maintaining strength.
The STU flywheel is recommended for forced induction and/or track and rally racing applications. This flywheel will work with all performance and stock clutch assemblies
BENEFITS:
* One piece ring gear for high durability
* Weight varies from 8 lbs. to 10 lbs. depending on application
* Well suited for Stage 3 and up clutch kit applications
* Stamped with 4140 plate with 2000 ton pressure at 1260 degrees
* CNC machined and balanced to O.E. specifications
* Reduced Mass = Increased Accleration
* Meets and exceeds SFI 1.5
Less mass on the ouside rim is a big factor in reducing the rotational inertia of this flywheel.
The distance the mass is located from the center of rotation is very important to the value of the moment of intertia.
Will Not work with the 6 speed S-15 transmission
Z1 Motorsports KA24DE 4140 Forged Steel Light Weight Flywheel $318 CAD shipped
The ST flywheel is recommended for naturally aspiriated and/or street driven applications. This flywheel will work with ALL performance and stock clutch assemblies.
BENEFITS:
o Preserves low end torque and drive ability
o One piece ring gear for high durability
o Weight varies from 11 lbs. to 14 lbs. depending on application
o Well suited for Stage 1 and Stage 2 clutch kit applications
o Stamped with 4140 plate with 2000 ton pressure at 1260 degrees
o CNC machined and balanced to O.E. specifications
o Reduced Mass = Increased Accleration
o Meets and exceeds SFI 1.5
Z1 Motorsports KA24DE 4140 Forged Steel Ultra Light Weight Flywheel $348 CAD shipped
BENEFITS:
1 piece driveshafts:
1-Piece Platinum Driveshaft S13 $328 CAD shipped
Z1 Platinum S13 1-piece driveshafts are designed and built to the highest standards to provide the smoothest ride available from a 1-piece unit.
The Platinum Driveshaft also has a benefical weight loss versus the 30lb+ stock driveshaft. These shafts weigh an average of 10-14 lbs less than stock. The shafts are constructed of .065" wall tempered steel and are clear coated to protect against rust and road grime. The tubing used in these driveshafts was specifically designed by Spicer for use in driveshaft assemblies. Quality Spicer yokes, U-joints, and hardware are also used.
For more weight savings we also offer our driveshafts constructed from aluminum tubing at an additional cost.
Aluminum driveshafts are custom made per order and are not in stock.
5spd non abs
5spd with abs
automatic
S14 coming soon!
Shifters:
AMS 240sx/180SX/Silvia Short throw shifter $95 CAD
• The AMS Short Throw Shifter replaces the factory assembly and is designed to optimize shift feel, while shortening throw by approximately 40%!
• Base is constructed of billet T6061 aircraft grade aluminum
• Shift lever constructed of premium grade steel for ultimate longevity
• OEM shifter bushings are included
Mounts:
Nismo Engine and Transmission Mount Kit $250 CAD shipped
Mounts will fit all Nissan 240sx’s and 180sx’s with a KA24DE or SR20DET motor.
These mounts are new in box and a genuine Nismo product. This is for all three mounts ( 2 engine and 1 transmission).
Thanks
Kevin@AMS
