I need these parts ASAP!
B-series parts
LS B18b/a lower timing belt cover
B16 upper PS bracket
Upper B16 radiator hose
cat converter (can be empty)
B-series parts
pump belt throw out bearing check
Getting them all new.
New is good free is better…hah
Yea I may grab the pump and bearing.
lmk
bump
bump
I have a b18 powersteering bracket and also a convertor… not sure if b16 or b18 are different…
They are different, must be a b16 one. Is the converter the hacked up one? I need a stock one for the flanges to line up.
i got a minty ek ex cat when your ready to swap that out…lmk.
yea its the weld in one… are you putting it on the teg? if so that convertor is part of a 2 1/2 exhaust from my dc teg… thats a solid exhaust mandrel bent so theres no flanges weld that cat on one end and whatever muffler you want and ur all ready to go… cat has the flange to bolt to ur manifold…
I already have a complete gsr catback on it that I’m using. Just need something to bolt in place.
