WTB: bunch of stock parts
i’m trying to collect parts to swap my sohc automatic to dohc 5 speed since i have been given the motor and tranny for free.
here is a list of parts i need:
clutch pedal
clutch MC
clutch line
clutch slave cylinder
5 speed brake pedal
DOHC ECU
DOHC wiring harness and body harness to engine harness connector
5 speed tranny cross member
5 speed driveshaft
i’m sure theres more that i’m forgetting at the moment.
if you have any of these and are within an hour of the kitchener/waterloo or london region then PM me or add me to MSN simplemind7[at]hotmail.com
thanks.
got it, located in kitchener
here is a list of parts i still need:
clutch line
5 speed brake pedal
DOHC wiring harness and body harness to engine harness connector - really need to get these!
5 speed driveshaft
also need a power steering resevoir and line to the pump
you can also call me at 519-317-1777, my name is Brendan
pretty sure i’ve got a wiring harness, still need:
clutch line
5 speed brake pedal
5 speed drive shaft
power steering reservoir and line to the pump
i’m now done holidays so i’m located in london.
i got a manual brake pedal… $20 but im in toronto
if your going to be around anytime just give me a pm
bump, still need all of this
i have a rhd front clip with the clutch brakes slave and i beleve ps resevoir etc.
416 827-5453
Mael
ive got the drive shaft
50 bucks
all i need now is the driveshaft and power steering crap. i have leads on the parts close by, but i’ll let you guys know if it doesn’t work out. thanks
I have ps reservoir and pedals. Let me know if u still need. (647)407-3938
don’t need anything, i did the swap on the weekend and everything is good. thanks for the help guys.
