need a passenger side engine mount
Type of car???
I have one that came with my SR.
20 dollars??
its for an 89 240… btw … if a ca’s going in do the mounts need to be different?? if so then i need ca mounts but im pretty sure my stock mounts work correct??
If you’re doing a swap you might as well get brand new engine mounts… makes sense while the engine is already out of the car
yeah but is it ok if i still use the stock mounts for the different motor??
I am almost 100% sure that CA/SR/KA mounts are all the same
you also have a PM
i have some leftover ka mounts when i threw in my nismo mounts,ka and sr mounts are the same,unsure of ca
$20 each
