so my bracket slider is seized and im looking to buy a new but used bracket. anyone have one for sale?
ABS or non ABS -the brackets are different -ABS is larger
Non-abs
Any difference between the rear ones? As i have both rear brackets
got S14 non-abs fronts… full brakes though…
shit, sorry for not being specific. i’ve got a 92 s13 hb, non abs. and ye there is a difference. and im only looking for the driver front.
If your bracket is still good with just the slider part stuck try loosening the small boot–soak the pin in WD40 -put the pin head in a vice and use the bracket to move it back and forth.I have also put a bar thru the bracket for additional leverage-this has worked for several of our S13’s. Once apart clean everything and lube both parts -sometimes you have to replace the pin if the vice damaged it to much.
ye, i’ve tried drenching it in wd40, but its still messed up, id find it easier just to buy another bracket, rather then more bottles of wd40 and wasting my time…so does anyone have one for an s13?
