WTB: Honda B-Series Parts
Looking for del Sol B-Series shift linkages…(I know it’s a long shot on here…hoping to find one local)
Also in need of OEM 94-01 Integra motor mounts. The ones with the rubber that bolt to the frame rails (and rear mount…bolts to the subframe).
LMK what you guys have! Thanks!
u realize delsols are setup the same as eg’s so stock dc2 or em1 linkages will work
also u can use a da linkage ur shifter will sit more forward tho and if ur in a pinch i have a da linkage if u need it but for $125 u can buy a innovative linkage online well worth the money
Nope. Del sol have their own linkage and are not interchangeable
Nah dude. Del Sol linkages are del Sol specific and are different than EG/DC/EK linkages.
I have the dc mounts if u still need em.
I should have all the mounts except the side trans one. Car was auto, so I believe that mount won’t work for you. Pulling the engine this weekend. Pm an offer on them if you want.
I found an entire mount set AND linkages already (will have them Friday), except the rear mount (firewall). I can get a new one off eBay for $20 shipped, so unless you guys want to part with JUST that mount for less than $20, I’m gonna just grab one off eBay.
Thread can be closed/locked. Got everything I need! Thanks.
