Like the title says i need one. doesn’t have to be complete. i just need the arm with the shaft in tact.
thanks
Jim
thanks
Jim
jim i have 2 for a eg … they are the same … ill text you
no shit! as long as they fit man.
u sure the spindles are the same? I could’ve sword disc vs drum were different
yea they’re different. i just talked to him.
i know theres a conversion kit out there but im not trying to spend a assload of $.
i know any 90 and up integra TA will fit. that and a 99-00 si…but good luck finding one of those.
is that all you need is the spindle? I know I have a set of drums but might still have one disc laying around the shop
apparently the spindle is riveted in the trailing arm. everyone ive talked to said i’d need the trailing arm with the spindle in it. thats how it comes from the dealer.
if you look here this is how it comes. i don’t think you can just swap the spindles. idk
the arms are the same its the spindle that is diff … jim you can have mine and take it apart and check it out … I can bring it to work
to make a drum brake a disk brake you need a fancy little bracket.
ah here it is…
http://www.honda-tech.com/showthread.php?t=2251647
i don’t want to hassle with that.
ive got a set of dc teg rear disc trailing arms, they come with calipers ect, 150$
like rust free from the south, wheel bearings are good ect. they even have ebrake cables on them.
bump
