WTB: Misc Parts (read if you have junk lying around)
-1 of the 2 bolts/screws for the distributor cap on an S13 KA24DE
-1 bolt for the back side of the power steering pump bracket (it goes through the swiveling bracket into the back of the power steering pump)
-Optima Redtop (preferably with receipt/warranty left over)
I will update later once I get more money.
Oh, I forgot to mention some stuff. The bolt for the power steering pump is for an S13 HICAS pump, assuming that it makes a difference.
More parts:
  • New exhaust hangers (preferably the poly ones).
-The little covers around the rear speakers which have the semi-circle slots for the rear hatch privacy cover to snap into (mine broke).
-Knock sensor in excellent condition (no cracks)
-Z32 MAF Pigtail (don’t need it now, but w/e, might as well)
-370cc SR20DET injector pintle caps
-Screws for injector caps (not stripped, lol)
-Nismo FPR
-Rear brake calipers (preferably rebuilt) for ABS S13 with the corresponding bolts
-Rear brake rotors (S13)
-Rear subframe S13 (non-hicas)
-Bings rear-multilink (in good condition)
-KA24DE Oil Pan with bung for oil return line already welded in at the correct location
-Torque wrench (the one that you can adjust, and it clicks when torque is achieved, not the old school bendy meter things lol)
-Breaker bar/pipe to put on ratchet when dealing with @)#($*)(#$)# bolts.
-New vacuum lines (ones that are easy to change)
-New/minty brake lines (rear)
-Red/black OEM sideskirts + rear valence
-Timing light
-KA24DE tubular exhaust manifold + downpipe that FITS (T2 bottom mount + SR downpipe or T3 top mount + custom downpipe, I will base my setup off this anyways…)
  • Any of the following in mint condition: GTi-R T28, S15 T28bb, GT28RS, Garrett T3/T4 50 trim w/ 0.48A/R Turbine with corresponding oil/coolant feed and return lines
-AEM Uego Wideband (preferably new)
-DSM BOV
-550cc injectors (preferably rebuilt Deatschwerks w/ flow reports)
Hopefully that covers it for now. PM me with prices if you have these parts.
Thanks for reading,
Ahmad
I have 2 s13 non-hicas subframes.
$100 each, you can pick.
I pretty much want the whole rear end including ABS VLSD and spindles, so I can powdercoat the subframe, replace all the bushings, buy aftermarket multilink and install it all at once.
Just post up a picture of what’s included, that’ll clear up any further queries about rust, etc.
Thanks Samson. :slight_smile:
have a selection of bovs to choose from including dsm $20
Scratch timing light off the list. :slight_smile:
Lots to go. I’ll be getting paid in about a week so post w/e you might have going up for sale around then.
i have a 3/8 torque wrench (it will click) for sale…make by signet!..pm if u interest!..ask for $30
i gotta s14 subframe with vlsd, grab some offset bushings and ur good to go.
