I need an oil return line with flange from a T28 I think it’s the same as a T25 too.
If anyone has one that they don’t need I would like to buy it, thanks.
I’m not sure what flange you’re referring to but don’t T25/T28s just use
the stock line with the banjo-bolt ends? :dunno:
Get some baller Taka lines from bings; probablly well worth it in the long term.
The oil return is the little line thjat comes off the bottom of the center peice and bends about 40Degrees and then connect with some normal lines. there is a 2bolt gasket that will be needed
YES! thank you Benson, that’s what I need.
Oh and G I got the turbo line kit from Bing, it doesn’t come with a oil return line.
I have an oil return line in my garage, it’s either from a s15 t28 or a ca18 t25 not sure on the angle but you can have it.
No gasket tho, you;ll have to use liquid gasket or make your own.
i have one from a T25. it needs to be modded to work on a GT28 though. for the gasket just order one for a 300zxTT, supposed to be the same.
Okay I got one last night all thanks to Mike (Mikeness) Thanks for the freebie dude
Please lock.
Watch out, he will ask for the favour back in ways most men do not like to pay back debts
:shock:
