Like the title says, doing a manual swap. Not sure if the s13 flywheel will work, since there is a sensor (cas?). Anyways, need the driveshaft and flywheel if possible.
Pm if you have
Pm if you have
I’ve got a fidanza flywheel for ka. . .came out of my s14 . . . barely used $100
I have a flywheel…PM if interested. $50
ok found out s13 flywheel works no problem…need the driveshaft tho…anybody?
auto 5 speed…abs or non… i just got out of this boat u will never find a non abs s14 drive shaft anywere in alberta i got the last one
just get the 1-piece . . .
Mine right now is Auto ABS, im swapping in a 5 speed…so i guess i want a 5 speed ABS driveshaft.
ya u will …and that drive shaft shop .co all the s14 shafts are on back order there are 81 people a head of me 16 days a go to get one made
