WTB S2000 Parts & 5x114.3 Rims
PM me if you have anything
Parts i still need:
-Passenger AP1 Headlight (must have ALL tabs intact, my headlight has 1 tab missing. Doesn’t matter if it has the ballast and bulbs, i have them)
-Front OEM Fenders (any color is fine, they MUST be perfect condition)
-Front Fender liners Driver and passenger
-AP2 rear bumper or aftermarket rear bumper (must have all the tabs in perfect condition)
Parts i want:
-5x114.3 Staggered Rims 17" (2) 9" wide, (2) 8" wide, 45 offset
-AP2 center console
-Ap2 door panels
-front splitter (functional)
-Front lip (air walker or j’s style)
-Trunk wing (oem or aftermerket style)
I have 18" black 5x114.3 wheels and tires
I still have the torques. Ill cut you a good deal. I just need em gone. $300.
Cliff, that is a good deal. I really want a staggered set but that could hold me over for now. Will they work with a 2" drop? And will the tires pass inspection?
Staggered?
They’re staggered. 7.5 and 8. 215/245. Offset is +48 so I think you should be okay… suspension is stock. So I’m not sure on the drop. Tires can pass inspection. They only have roughly 6000 miles on em and a few Autox. They wont last a whole season but should be good for inspection. Figured since the one took a good hit at the cost of a new rim + mounting for 4 new tires your still saving close to 200 dollars. Got em last spring too.
Rim was rebalanced and has never lost Air. Like previously discussed only cosmetic.
Rears are questionable. If I had a tread depth tool I could give you a definite answer. Fronts have more that. Enough life and can last you rest of season.
as long as they will pass inspection i will take them cliff, and for 300- i cannot argue with that. My current tires are shot, so it is between buying new tires for stock rims or buying rims with good tires. pm me ur number and i’ll give you a ring this weekend most likely to take a look at them
