like the topic says i need a throttle body that would work on the sr20det. if u also have the throttle posiiton sensor then that would also be great
thank, ken
thank, ken
i have a 60mm throttle body that came off a sr20 for 60$ + shipping to edmonton!
I also have one off a KA24DE, its slightly bigger than the stock SR one and i do believe its a direct bolt on…RS13 would know for sure.
the one i have in my car right now is a zenki one i think and it doesnt work at all… maybe the ka24de one will work… but im not sure… my car dies whenever i shift it to neutral
pls give me your numbers so i could call u if i need it! thanks
The KA ones works fine. However the plug for the TPS does not match up but just connect the wires of the same color.
Also the TB posted above is from an KA automatic. Make sure you get the STD tps as it only has one plug.
thanks for the info RS13
