1st
Zex Dry kit, 75hp, includes lines, brain, jets, brackets and (empty) bottle. I took the cover off the brain box dealy, because I was planning on just using the solenoid and having my ECU control it, I think I lost 2 of the screws, but that’s it. Kit shows signs of use, but should work fine. I never got around to using it.
$150
2nd
Everything needed to do a Mini-Me in an EF(and most of the stuff to do it in an EG). D16Z6 head, drop in EF wiring harness(monotech), gaskets, adjustable timing gear, timing belt, ecu, new/refurb distributor, and a Skunk 2 pro series intake manifold and throttle body.
$350
