GB! OEM NISSAN PARTS! pricing NOW available.
discounted brand new OEM parts.
approx 10% off depeneding on the part. some more some less.
POST UP the oem part number and quantity.
I will be putting this order through asap so there will be a tight deadline for this…
how tight is the dead line? will it be around a week from now?
would you get quotes first?
Does this include Nismo parts?
the chick at the counter of oakville nissan will give you 15% off all orders if you flirt with her :stuck_out_tongue:
suck my cock and i might give you 20.
i need part numbers to give u quotes.
Does this also include JDM parts?
Can i get quote on
Water Pump (s13)21010-52F01 (JDM # SR20DET)
Exhaust Manifold Gasket 14036-53J00
Nismo thermostat 21200-RS420
Nismo Radiator cap 21430-RS012
Nismo stuff isn’t discounted much anywhere.
If you get the JDM part numbers like you did. Nissan can get you any part you want.
I called and got the… “well it isn’t in the computer so there is no way I could help you out. Maybe if you bring in the part we can compare it to other USDM parts and see which is the same.” … :roll:
i’ll check for you. id like to get some jdm shit for myself too so we’ll see how it goes
so i’ll be getting the first round of prices tonight… any one else want in?
just post a part number…
for those s14 guys… s14 manul shift console? radio trim? busted up door trims etc… nows your chance!
They don’t still keep S13 interior trim pieces do they? And like miscellaneous exterior pieces? Do you know where I could get the part numbers?
call your local dealership and ask the parts guy to look it up for you.
All these parts is for a 1988 200sx Turbo
Vavle Cover Gasket = 13270-D0101
Window Bolts = 80760-21F02 <-- I need 4 of them please
Driver side Door Handle - thses pare numbers mirght be it. but might be for the passenger side, I need the driver side tho. or they might be the same for both sides…
80670-01F00 or
80670-01E01
80670-D4011
Driver side power window assmbly buttons
  • 80952-01F00
Backwindow handle for passsender side. = 83611- 15F00 might be 15F01, 15F02, or 18F00 but their computer should say the right one for that year and turbo model
Tachometer Assembly = 24825-11F00 it might be 01F00 <-- but that is for the turbo model in europe. dunno the one for canada… could possibly be 24825-31F00 as well
Radio Antenna - 28205-15F00 , can be 15F01
air vents inside car (need both of these
-68750-01F00, can be F01, F02
-68755-01F00, can be F01, F02
sunroof related parts- seal - 73873-15F00
hinge parts (need them all) -
73862-01M20
73863-01M20
73864-01M01
73865-01M01
I need to replace my air control lightbulbs but dunno the part number
can be 27625-01F00 or 27525-01F00 ,… or both
decals!
84894-01F02 and
84898-11F00 and
62890-32F00
Hood stuff
65150-04F01
65814-04F00 and
65840-32F00 or 30F00
lol that’s all I can think of…
ty
arrr i want in on this… i went in to the dealership by my house and the old fart said the parts dept was closed and i couldt get any numbers illl get them asap
im looking for
driver and passenger inner door handle cover
5 spd shifter consel
call village nissan. their parts dept is open until 3am.
21010-00001 - Water Pump Assembly - 1990 to 1996 300zx
21200-00001 - Thermostat - 1990 to 1996 300zx
A192M-00001 - Drive Belt - A/C compressor
A172M-00001 - Drive Belt - Fan & Alternator
A192M-00002 - Drive Belt - Power Steering Pump
13028-00001 - Timing Belt
14055-00002 - Front By-Pass Water Hoses (QTY 2 included)
13022-00001 - Front Crankshaft Sprocket Plate
01001-00002 - Camshaft O-Ring Seal (QTY 2 included)
13042-00001 - Front Camshaft Oil Seal
13072-00002 - Tensioner Spring (QTY 2 included)
13070-00001 - Timing Belt Tensioner
13042-00002 - Camshaft Oil Seals (QTY 4 included)
21014-00001 - Water Pump Gasket
999MP-00001 - Nissan Silicone Gasket
Thanks,
J.
sorry for the delay. i was waiting on a few others who needed some parts so i could send it in at once. price quotes coming up. they’ve been submitted awaiting response.
the following parts are priced at retail. For YOUR price simply take 10% off. Please respond with which part you are ordering and EMT payment to sales@raceready.ca (the discount does not apply to core charges). sales tax applies.
21010-22P27 - water pump assy 90 to 96 300zx $114.99
21200-42l01 - thermostat 90 to 96 300zx $ 19.31
A1920-F6501 - drive belt a/c compressor $ 21.65
11720-V5303 - drive belt fan/alternator $ 25.39
A1590-F6501 - drive belt power steering $ 20.10
14055-F6511 - f bypass water hose (ea) $ 6.00
13022-45V00 - f crankshaft sproket plate $ 5.03
01001-00191 - cam o-ring seal (ea) $ 8.96
13042-42l00 - f camshaft oil seal $ 11.38
13072-45V20 - tensioner spring (ea) $ 5.21
13070-45V04 - timing belt tensioner $404.96
13042-16V00 - camshaft oil seals (ea) $ 10.94
- water pump gasket n/a use silicone
99998-50506 - silicone gasket $ 13.15
46010-30P01 - brake master cylinder $376.16
22680-30P00 - mass air flow sensor $549.95
22100-40F00 - 93 240sx distributor $599.95
+$60.00 core charge
25060-35F01 - 93 240sx fuel sending unit $288.09
44011-69F01 - 95 240sx FR brake caliper $300.64
+$75.00 core charge
20800-53F26 - 93 240sx cat converter $719.24
37000-53F05 - 93 240sx driveshaft $928.92
37000-65f01 - 95 240sx driveshaft $844.46
54303-54f25 - 90 240sx strut $213.33
54302-54f25 - 90 240sx strut $213.33
44001-35F01 - 92 240sx rear caliper $223.97
+$75.00 core charge
44011-35f01 - 92 240sx rear caliper $223.97
+$75.00 core charge
43206-68F00 - 92 240sx rear rotors (ea) $ 74.29
44060-9V590 - 92 240sx rear brake pads $ 98.12
49001-53F01 - 92 240sx steering gear $1294.40
21010-40F27 - 92 240sx water pump $ 77.49
25060-35F01 - 90 240sx sending unit $288.09
40206-AG020 - 90 Q45 front rotors (ea) $105.11
41011-64u11 - 90 Q45 front caliper $539.04
+$75.00 core charge
41001-64U11 - 90 Q45 front caliper $539.04
+$75.00 core charge
Nissan 97-98 240sx headlamp assemblies
®26010-81f25 $ 724.58
(L)26060-81f25 $ 724.58
Nissan 95-98 5 bolt front hubs
40200-0V210 $ 217.72
Nissan Skyline R33 E brake cable
36531-15U10 $ 115.97
S15 Headlamps
(L)26060-85f25 $ 779.09
®26010-85F25 $ 779.09
1988 200SX Turbo
Valve cover gasket 13270-D0101 $ 21.01
Driver door hanle 80670-01E01 $ 32.60
80670-D4011 $ 23.35
Back window handle 83611-15F00 $ 27.34
83611-15F02 $ 27.34
Sunroof 73873-15F00 $ 125.70
73862-01M20 $ 57.02
73863-01M20 $ 57.02
73864-01M01 $ 6.55
73865-01M01 $ 6.55
Air control bulbs 27625-01F00 $ 7.81
27525-01F00 $ 4.97
Decals 84894-01F02 $ 12.53
84898-11F00 $ 16.02
62890-32F00 $ 49.85
Hood 65840-32F00 $ 96.19
