1-Piece Platinum Driveshaft S14 Manual Trans (BNIB)
Z1 Platinum S14 1-piece driveshafts are designed and built to the highest standards to provide the smoothest ride available from a 1-piece unit.
The Platinum Driveshaft also has a benefical weight loss versus the 30lb+ stock driveshaft. These shafts weigh an average of 10-14 lbs less than stock. The shafts are constructed of .065" wall tempered steel and are clear coated to protect against rust and road grime. The tubing used in these driveshafts was specifically designed by Spicer for use in driveshaft assemblies. Quality Spicer yokes, U-joints, and hardware are also used.
Fits ABS diffs
Its new in box. never installed in any vehicle.
save yourself s**t load of shipping headache, TAXES and brokerage!
$$290 CAD
located in oshawa, can deliver up to scarb.
Might want to indicate whether it is for an ABS or non ABS differential setup…just a thought. GLWS
yep i forgot
thanks dude
Pm’d
Sent from my SGH-I747M using Tapatalk
sold
