18" tires
Looking for some cheap take-offs/used tires to get me threw a couple months while I dial in my suspension so I don’t put on brand new rubber and trash it before getting it worked out and aligned…
would gladly run:
225/40/18
235/40/18
225/45/18
235/45/18
245/40/18
245/45/18
marginally pass inspection is OK, cheaper the better. as long as they aren’t snow tires I’m interested. GO!
bump!
I run 225/40/18s on my vert, on discount tires direct you can get some as cheap as $80 per tire shipped.
I have some 18’s I’ll check what sizes
I have 2 265/35zr18 Some camber wear but they’re still good
35$ each
Located in bonerville
265’s are too wide, these are going on 18x8" wheels.
still in need of 18" tires…
Take my 265’s! They’ll look wild on your 8" wheels!
won’t they be pinched real bad?
BUMP! still need 4 tires.
DirtyE30 was awesome and set me up with a pair of 255/45/18’s, but I tried one on and it was much too big.
Ideal size would be 235/40/18…
:frowning:
still need some cheappy used tires
bump
i have a wack of tires in these specs that will work for you.
4 x 245/40/18 Duro Perfoma with like 65+ % tread
2 x 235/40/18 Toyo T1R 35% and a bit messy from being on the front of my car at dunn tire drifting
2 x 235/40/18 Michelin Pilot Sport 80%+
all in hamilton.
The Duro’s were reasonable street tires… like running a Nankang or something else gay
I have a set of Yoko Advan A13’s off a Evo X. They are a AA-180 i believe so pretty tacky for hard driving. There a decent set -. 200$ LMK
