4.5" Silencer made with T-304 Stainless Steel
Asking $20
You’ll notice that the hole is much larger to allow for better flow than the ones you can buy at crappy tire
Key ring light: Comes with blue wide angle LED illumination. Will fit all S13 240/180sx and can be installed easily by tapping one wire into 12v and grounding the other.
Asking $40
Xenon H4 (Cyber White) Bulbs for headlights.
Bought these before I decided I’d get HIDS. The light it much brighter and whiter than stock and are D.O.T approved. Are plug and play with H4 housings and are rated at 12v 60/55w (which is stock output/current draw so there is NO risk of damaging/melting your wire harness)
Asking: $15
