this is a long shot but ill try anyways. I’ve had this car since november of 2005 it has been my DD for all that time and has hardly had any problems. oil is changed every 3500- 4000 km’s with Mobil 1 15w 50 synthetic. transmission oil was just changed with Redline synthetic and the diff was changed out with Motul 80w 90 dino oil.
1985 Toyota Levin Coupe RHD, 162 xxx km’s, 5 speed, no sunroof, Red Brown interior, power mirrors, removed AC/PS. This car is a Blast to drive and babied since I’ve owned it. The car has some rust on the drivers front fender arch, and some scratches in the paint (bought the car with them) Car is located in Lethbridge.
Engine:
Map sensored Bluetop 16 valve 4age, HKS Mushroom filter, HKS Cams, High Comp pistons, High flow oil pump, Apex-i 2 ½ inch 4 to 1 header, Block heater, T3 test pipe, 5’zigen rocket Catback under axel 2 ½ , New stock rad, Spec rad cap, TRD plug wires.
Drive Train:
TRD 2 way LSD, Trans Rebuild with TRD gears (P# 33030-AE811), 5.1 final drive, Aftermarket Clutch, Lightened flywheel, TRD short shifter, Solid Shifter Bushings, Rebuilt Clutch master.
Suspension:
(Front) Revolver Coilovers 8 kg/m, NRCA’s, Camber plates, Cusco Strutbar, (Rear) TRD springs 6kg/m, Gab Adjustable shocks, Adjustable Panhard.
Brakes:
SS lines all around, Hawk pads, Cusco Brake master stopper.
Interior:
All sound deadening has been removed, interior has been painted white, full interior is in the car, MOMO steering wheel, MOMO wheel hub’s (2), MOMO horn button, Omori Water Temp, Checkered Floor mats, Blitz Vacuum pressure gauge, TRD leather shift knob, Cusco Spin turn knob, Revolver 6 Point Cage (padded), JVC CD player.
Exterior:
Color Change from white too red, Tinted Rear windows, Brighter Headlights/Reverse lights, Advan A3A’s 14x6 +6, Bridgestone Potenza 910 185/60 R14 90% tred , SSR Mesh Spare 14x6 +6.ill toss in a full set of snow flakes for the buyer and the whole AC system.
8000 obo
pm me or muttle at gmail.com
Also will take a nissan 240sx or toyota 4x4 on partial trade depending on condition.
