Posting For a Friend
1986 Monte Carlo LS. New motor just rebuilt by KS. Motor has about 100 miles on it if that. Newly rebuilt transmission which also has about 100 miles on it. The body and the frame on the care are very solid with no rust. set up to be a street strip car.
Car has alot done to it;
-ford 9 " with all moser parts 4:11 gears and a spool
- adjustable schocks and trick springs
-10 gallon fuel cell
-6 point roll cage
-4" fider glass harwood bolt on hood
-new tires
-slicks on rims
Too much to list
Motor consits of:
-.030+ SBC 400
-Eagle crank shaft
-Crower connecting rods
-keith black pistons
-Dart pro one aluminum heads
-pro comp roller rockers
-Comp cams xe-284 camshaft
-Moroso high volume oil pump with 7 quart oil pan
- motor is about 9.5:1 compression ratio
im looking to get 5500 out of it or im open to trades. Call or text 716-725-9103
Pics Can Be Seen Here
http://buffalo.craigslist.org/cto/1400301703.html
