89’ Ford F-350 Box Truck for sale:
Box is 15’ floor space and 3-4’ “grannys attic” above cab.
136k miles, 5.8L FI V8, Automatic
I bought this to use as storage about a year ago.
Good
The previous owner dumped $2000 into it before he gave up.
New parts included:
Tires have less than 5000 miles. 215-85-16LT Daytons
Brakes
Exhaust (stock torperdo convertor still there)
Battery
Bad
Apparently the Fuel Pump Control Module? would overheat or short out after 10-15 minutes of driving and the truck would stall and not be able to start back up for 20 or so minutes. Engine has a slight miss at idle?
Since I’ve been using it for storage the trans cooler lines have rotted out.
The box sides are beginning to separate from the floor, but can easily be fixed with a 2x4 and some lag bolts. The cab rockers have rust, as do the doors. This is a truck front end, not a van.
It will start with a jump, but don’t expect it to move under its own power with out fixing the trans cooler line leak.
For sale as-is where-is. Will need to be towed, must be able to remove from where it is currently parked I have no way to move it right now.
My need for it is now gone and it MUST GO NOW.
I don’t care what you do with it, price listed is scrap value.
Any other questions feel free to call, text, or post.
Jeff @ 716 570 3082. Have a few pictures I can text.
$800
Located in Lancaster on Cemetery Rd. near Erie St.
