SOLD
1989 Silvia K’s. Chassis KM is under 150km
Non-abs, all power options
Original Slicktop
-Legally re-vinned with an Ontario 32 digit VIN (Avoid all the hassles with insurance/registration associated with a JDM vehicle!)
-Stereo relocated to glovebox, taken out as of right now but can be put back
-Yonaka seats with 4point harness installed
-headlights, tail lights, signals all functional
-AEM wideband
-Autometer Carbon Boost gage
-Grant deep dish steering wheel/hub
CHASSIS/SUSPENSION/BRAKES
-Zero rust on the chassis
-14 point welded Halo cage. Door bars angled to give maxiumum clearance when entering/exiting the vehicle
-Front fenders have been tubbed to allow for extra clearance at full lock/big rims.
-All four fenders have been professionally rolled/rears pulled for wheel fitment/clearance
-Interior has been completely coated in POR-15 to prohibit rust from ever forming
-Underside has been rocker guarded
-Engine bay sprayed custom Pink w/blue metallic flake
-Vertex bodykit
-Carbon fiber hood with locking aerocatch hood pins
-GTR grill
-Brick headlights
-Megan street coilovers 10k/8k
-JDM s14 rear subframe
-JDM S14 vsld
-BINGS rear multi-link
-OEM s14 5-lug
-ARP Extended studs
-Front 30mm z32 brakes
-SS brake lines front/rear
-Brand new Stoptech rotors, with brand new HP+ pads all around.
brakes have only been broke in, havent been drive after that
-Tanabe swaybar front swaybar
-MB Battles 17x9.5+15 wrapped in Fuzion HRi 225’s
MOTOR:
-S13 SR20DET redtop with approx. 110km
-Extensive wire tuck, fuse boxes relocated to under dash. NO wires visible in the engine bay
-All engine fluids changes done with Mobil 1 Synthetic
-Eurodrive 6-puck ceramic clutch, Stage 2 pressure plate, resurfaced flywheel, brand new slave
cylinder with SS braided line from slave cylinder to the master
-BINGS v.2 adjustable height short throw shifter
-S15 Spec-R T28 turbo
-Taka SS turbo*lines
-Megan Manifold
-HKS 12lb actuator
-Turbo-back 3’ exhaust (megan elbow, apexi GT dp, vibrant highflow metal-core cat, apexi n1 cat-back)
-Monster aluminum fmic kit. Reinforced couplers, T-bolt clamps, TIAL 50mm bov
-BINGS aluminum coolant overflow tank
-Koyo Aluminum rad
-Altima fans. Dual stage, with highspeed switch located underhood.
-Walbro 255 fuel pump
I Have a bunch of spare parts that will give away with the car.
Spare clutch and pressure plate, 7 layer exhaust manifold gasket, turbo gasket, wheel bearing/hub, wideband sensor, front metal overfenders, Set of Hoosier Slicks
The downsides.
The car could use a paint job. Stickers have been peeled off, and they took some paint with them.
Front aero bumper is cracked, but still structurally good.
The price is $8,500 OBO
No test pilots
For more info feel free to ask.
416 875 5708 call or text anytime
