Selling my project, moving and need the space and money.
it is AUTO
233000 on the body
Im not parting anything, buy it all or kindly buy nothing.
Frames been patched by a licensed welder, and got the OK from my mechanic. floors have been patched using body steel, a ton of screws and silicone then painted with rubberized undercoating, i fixed the hatch and put a new rad support in it… minimal body work remaining. This car has been driven for approximately a month over the past year and a half, ive been putting money into it since then. All new stuff is totally stock. All premium parts.
New:
Fuel pump
Tank straps
Calipers
Slotted rotors
Premium pads
Ball joints
Lower A arms
Tierod ends
Brake lines
Fuel lines
Master cylender
Sway bar links
Pioneer stereo
Speakers in the rear
Fancy hidden antenna
Probably some other stuff that im not remembering
Theres a spot in the back of the car that needs attention, where the last exhaust hangar is (was)… the point is, theres not much frame there anymore. other then that, Its ready for the road, or drift track… uhh needs a passenger seat (long story)
Comes with a set of 17" Enkei rims and stock rims with new tires. (and a set of black tuner lugs) The engine has 0 KM This motor was completely unhurt when i pulled it, it was leaking oil, and the oil rings were no good, the block has been hot tanked, honed, painted. Has new rings, new gaskets, ALL new bearings, frost plugs… now, the motor is still somewhat broken down, but the hard work is done, its ready to be put back together. I was building it for 300hp on boost. I haven’t skimped on this build and everything was done to the best it could be done. I can put some pictures up at request. Honestly, I hate to sell it. Im not going to hide anything so buy with confidence. Ive also got an engine stand and a lift (bought them brand new for this build) if you want them its $300 for the pair. The motor now has cams and timing installed.
^^Before i fixed the hatch^^
After
While i was breaking it down
$3500 OBO
Located in Tilbury, Ontario
If you have any questions feel free to PM me.
