1994 SVT Cobra pro street
1994 SVT Cobra Mustang with 50K on it. Listed below is all the details on the car. If you have any question please feel free to contact with them. For some reason I’m having issues posting pictures. 716 984 6305
Motor: 311ci svo built by RLJ performance engines
250 shot of nos on a wide open throttle switch and bottle warmer, electric water pump, AFR 1399c heads, Vic jr intake, Holley 650 carb, Holley dominator fuel pump.
All MSD electronics including Distributor, wires, 6al, timing retard, 2 step, window switch, and coil.
Transmission: Built 2 spd powerglide with 1.80 straight cut gears. Sfi rated bell housing and skatter shield. Transmission brake, hurst pistol grip shifter, reversed manual valve body.
Suspension and drivetrain: Hotchkis adjustable in the front and Lakewood drag shocks in the rear. Tubular control arms, tubular k member, drilled rotors, 4.11 gears, 31 spline moser axles, spool, Dedenbear delay box, and weld skinnies in front and weld 15x9 in the rear wrapped with slicks.
As for the rest of the car.
Certified roll cage, cowl induction hood, pair of kirkey seats,g force 5 pt harness, has full interior, painless wiring harness, lights work, fuel pump gauge works, and still has working power windows.
what she run
Best time was 9.55 1/4
as per his ebay ad
Best time for the car 9.55 1/4 but run a consistent 9.60’s
      • Updated - - -
looks like i was late
