Hey guys, sadly I need to sell my car I have had it for 6 years and have invested alot of money
into parts and labour to do the swap and upgrades.
I am going to try and list all the parts, as well as the things wrong with the car so there are no suprises.
I am selling the car as is $6,600 OBO Price drop
The body has 255,000 kms on it
The car makes 400whp @16psi and 330wtq, tuned on 94 octane.
The engine runs great and has good compression, transmission is pretty good, no grinding gears.
It is very driveable the way it is, I will take this week to try and fix the short and change the
wiper fluid motor fuse.
Im going to see what I can get for it as is, if im having no luck i’ll eventually part it out.
It’s a fast car and would be a great track car. The motor in it now is obviously used but since install i’ve only put 2000kms on it, and I have taken good care of this one
If I could do the body work myself I would keep it, but the rockers need attention.
The Bads:
-It needs work to the rocker panels I had to avoid driving it in the rain, and has a small bit of rust starting on the passenger strut tower, the rest of the car is doing pretty good for rust.
-Has a crack in the front bumper, and there is a short causing the wipers to stay on unless the headlights are on. I didn’t do any sort of detailing to the engine bay, but considering that it is still fairly clean.
-The paint is in decent condition, a scuff on the rear bumper and rockchips on the hood.
-The driveshaft needs balancing as it vibrates over 100km/hr not alot, but it does vibrate and its noisy.
-Rpm Gauge stopped working but should be an easy fix.
-The actuator should be replaced, it still functions but a new one with a better swingarm would be ideal.
-Rb25det series 2- Stock Internals 5speed w/ new oil pump
-3" custom exhaust
-Splitfire coilpacks
-Aem ems series 2 Ecu
-Five O 550cc injectors
-Boost Gauge, Air fuel Gauge
-Garret Gt3076r BB turbo .82 exhaust 2000kms since install. The actuator is old though.
-Greddy Intake Manifold
-CX Racing FMIC
- HKS SSQ4 Bov
-Aem boost controller(nothookedup, because of the actuator)
-Megan Racing Rear Upper/lower control arms, rear traction rods, inner and outter tie rods.
-Spec stage 3+ Clutch, Nismo slave cyl
-New oem quality clutch master Cyl
-4yr old Kyb struts, still function
-300zx front brakes, Skyline one piston rears stops on a dime, NO ABS
-Battery relocated to trunk
-Front wheels, 5zigen fn01rc 18x8.5 w/bridgestones
-Rear wheels, Enkei RP03s 18x9.5 +38 wrapped in nankangs, one tread pattern is different…
-Hubcentric wheel spacers
-Another engine block, that needs to be reringed can be included
Please PM me or text my cell at (905) 808-3976
