1997 BMW 328i. Located in Buffalo, NY. 4 door, 5 speed. Cosmosschwarz on black. Tons of recent maintenance. Receipt book going back thousands of dollars.
Southern car from Kansas. 171,xxx on chassis. Newer motor has ~110k on it. Runs great, steady idle. No leaks, no problems.
Some of the recent maintenance includes:
crank position sensor
control arms
tie rods
spark plugs
brake light switch
fan clutch
serpentine belt, a/c belt
upper and lower coolant hoses
thermostat
aluminum thermostat housing
front discs and pads - mintex red box pads, meyle rotors
Bavauto remanufactured driveshaft, 6 month warranty
Just changed the oil with Castrol full synthetic
Just changed transmission fluid, Redline MT-90
low mile motor installed in '07. clutch, water pump & oil pan gasket done at that time
rear pads done in '07
new exhaust from bavauto in '07 as well
tons more stuff that I can’t find receipts for.
6 disc changer. I removed it to better fit my hockey equipment in the trunk, but it is included.
a/c blows ice cold
fold down rear seats
all weather floormats
has 2 small rust spots on each of the front doors. Nowhere else. Has been keyed on passengers side door, covered with 2 stage cosmos schwarz touch up paint from BMW. Seatbelt light is on due to m3 seats. Would go off with stock seats. I preferred having the light on and getting comortable supportive m3 seats, but it’s up to you. Passenger’s side door tweeter bezel is cracked (cosmetic only).
Price:
$4400 on stock wheels with blizzaks
$500 extra for very nice e36 manual m3 seats - vaders. ((pictured). otherwise comes with stock power heated seats)
$600 extra for NEW bilstein sport shocks, slightly used h&r sport springs (uninstalled)
$300 extra for ASA 17’s with new tires
1000 extra for bbs rsII's with tires - 18x8.5" up front 18x10 in back. 225/40/18 up front 255/35/18 in back (pictured)
all mods for sale separately (will be a bit more though).
here it is on the ASA wheels
link to album to see pics larger
http://gs165.photobucket.com/groups/u46/LI2T0CVI0G/?sort=ascending?sort=ascending
lol…
