1g dsm maft 3" translator eclipse talon laser
edit, this is the newest and latest version
used, 100% working condition with all wires and connectors. I no longer have the car and have no need for this anymore. any questions ask
The 1G Translator will allow the user to use a late model GM MAF sensor on and 1st Gen Talon or Ecipse turbo car. This will greatly improve airflow and spoolup.
It can also be used as a blow through unit so that the blow off vave can be vented into the atmosphere with no bad effects.
If this was not enough it also has controls to adjust the air fuel ratio and compensate for larger fuel injectors eliminating the need for other more expensive units like the SAFC
pm me for more info,
located at 15024
$150
this is for just the translator right? i might be interested. currently have 650s and 2g maf running off my afc.
Edit:
Please post pictures.
http://www.pittspeed.com/forums/showthread.php?t=34948
edit.
