1ga motor into a 1gb car, dsm
i have a 90 eclipse gsx motor that is going into a 92 eagle talon awd. i want to know what are the sensors that i will need to find so that i can use the 1gb wiring harness. if you know or have any of the parts i need please let me know. also i am scraping the 90 eclipse so if you need anything out of it please let me know.
Everything should transfer over with the exception of the throttle body and CAS. Those on the 90 have harnesses attached and the later years do not. You can obviously make them work if need be. There will be 2 wires for the IAC different at the ECU. You can find the differences on www.vfaq.com as to what 2 you need to switch at the ecu. That is all I can think of off of the top of my head. Gary might chime in with anything else I am forgetting.
