1JZ/2JZ OEM Engine Parts/IS300 Coilpacks/Front Sump Kit. 1JZ CNC Flange.
Lots of my spare parts I’ve decided I do not need anymore.
  1. 1JZ Non VVTI Cylinder Head.
    -Buckets.
    -Shims.
    -Valves/springs/retainers.
    -Cam caps.
    -Misc hardware.
    Looking to get $200 for this.
  2. 1JZ Non VVTI Valve Covers.
    -$40/pair ($20 if you purchase the head)
  3. 1JZ Non VVTI CNC Steel Exhaust Manifold Flange.
    -Brand new.
    -Going a different direction with my project.
    -Stepped to accept 1 1/4" sch. 10 pipe
    -Shipping and duties sucked on this.
    -$100
4.Front Sump 1JZ/2JZ Full conversion w/ hardware.
-$200
  1. JDM VVTI 2JZ / IS300 Coilpacks w/ leads.
    $80
  2. Misc.
    -Polished (ebay) 57trim Garrett compressor housing with cast 90 welded on. $40
    -Ceramic coated .70 AR T4 twin scroll ‘Garrett’ Turbine housing. $60
    -1JZ/2JZ Toyota oil pump used it on my old engine. $40
    -1JZ/(2JZ?) Oil filter block, cooler/warmer. $40
Parts located in Brampton.
Text me at nine 05 four 60 four 829 for photos. Please do not call.
Do you have the 1jz vvti tps or ah maf
