What is your First & Last name? Rene Rebelo
What is your email? renerebelo29@hotmail.com
What is your phone number? -Optional:
What is your City? : Brampton
What is your State? : Ontario
What is your Zipcode? : 12345
Ad Description:
CANADIAN PRICES
Only Willing to part with everything once there is a buyer for the main parts of the car…(ie Engine/Tranny/Chassis/ECU/Brakes)
Some prices may be higher than normal, but feel free to offer me up something. (I am in no rush to sell everything)
Anyways it’s FS as a part out and its like an interest check more than anything.
JDM 2JZ-GTE Engine - $3500 o.b.o
Built Head / Stock Block
Head [Full Port & Polish] (2000 km)
BC Valve Springs + Retainers (2000 km)
BC Cams 272 (2000 km)
USDM Water Pump (2000 km)
USDM Timing Belt Tensioner (2000 km)
USDM Accessory Belt Tensioner (1000 km)
Tech 2 Pulley Kit (2200 km)
Earls Oil Sandwich Plate (2000 km)
ARP Head Studs (2000 km)
Cometic Head Gasket (2000 km)
N/A Filter Bracket
Titan Cam Gears (2000 km)
ATI Crank Damper (2200 km)
Toyota Gaskets
Cam Covers Polished w/ -10an Fitting installed
Upper Water Neck Polished
Lower Water Neck Polished
Coil Packs
GTE Cover
TDF Engine Mounts - $900 o.b.o
Engine + Tranny Mount [Billet Aluminum]
Intake Setup - $600 o.b.o
Lower Runner Porting [Also outside was polished]
Upper Runner Porting [Also outside was polished]
Intake Manifold Polished
Custom Q45 Extension + TB
Turbo Setup - $3700 o.b.o
Custom T72 Journal Bearing Turbo [Garrett internals] (2000 km)
Turbo Housing Polished
Vibrant Turbo Cast Alum Elbow 3"
Custom Manifold (Weirtech) (2000 km)
Oil Feed Line
Oil Return Line
Intake Pipe
Intake Filter (2000 km)
Couplers
Tial Wastegate (2000 km)
Custom Downpipe (2000 km)
Tranny Setup - $1800 o.b.o
1JZ Bell housing (2200 km)
R154 BIC Performance Polyurethane mount (500 km)
R154 Transmission ( 1st gear grinds and doesn’t go in)
R154 Slave Cylinder [OEM] (500 km)
1JZ Flywheel (2200 km)
Tech 2 Shifter Extension
Tech 2 Clutch Line
Stage 5 4-Puck Competition Clutch (2200 km)
Stance Coils - $1100 o.b.o
Stance GR Sport Specs (2200 km)
(Extra set of springs)
Wheels - $2500 o.b.o
Volk GT-U 18x9 +37 18x10 +44 (Plus Center Caps)
Hankook RS-2 235/40ZR18 (Front)
Hankook RSS 285/30ZR18 (Rear)
MCGuard Lug Nuts
Cryo2 10 lb kit - $300 o.b.o
New never used it just have the bottle mounted in car
Front Brakes - $2500 o.b.o
Brembo 4 Pot GT Series Brakes (2200 km)
Rear Brakes - $1500 o.b.o
Brembo Calipers
Big 13” Rotors
Custom Bracket
Fuel Setup - $3000 o.b.o (system has 2000 km)
Custom Fuel Rail
FPR
1000 cc Injectors
-10an Feed line w/fittings
-8an Return line w/fittings
Dual Walbro Pumps
Custom In tank hanger
Aero motive A1000 pump
Two Y Blocks
Two Fuel Filters
Custom Fuel Switch Board
Included Relays & switch
10 Gal Fuel Cell Polished
Rad + Fans - $480 o.b.o
Koyo KA Rad (2200 km)
Flex-a-lite Fans (2200 km)
included relay
NISMO Radiator Cap
Standalone - $2100 o.b.o
AEM ECU
AEM AIT
AEM 3 Bar MAP Sensor
GM Boost solenoid
Rear End Setup - $850 o.b.o
Q45 Diff
Q45 Driver Axel
300zx TT Driver Axel
300zz TT Hubs (Drilled for 14mm Knurl Studs
IC Setup - $600 o.b.o (system has 2000 km)
XS Power Intercooler 24x12x4
Tial BOV
IC Pipes
Vibrant couplers
Vibrant T-Bolt Clamps
Catch Can - $250 o.b.o
Catch Can
-10 an lines w/fittings
Stewart Warner Gauges - $200 o.b.o
Stewart Warner Boost Gauge
Stewart Warner 100-260°F Water Temperature Gauge
240sx Shell - $3500 o.b.o
Champaign Gold
5 Bolt (60mm Studs All Around 14mm Knurl also)
153 895 km
5 Speed
Comes With whatever wheels I have at the time
No brakes
Autometer Dual Gauge Pillar
Front Strut Tower Bar (Strut Bar Polished & Gold)
Custom Battery Re-location
Custom Fuse Box Re-location [In Passenger airbag]
Full Interior included (Leather)
4 point Cage (can Be Cut Out)
OEM Wheel
300ZX TT Brake Master
Stock Suspension
Infinity 6.5” Speakers
Sony Deck
OEM Hood
Power Windows
Lights
Tinted windows
Power Mirrors
Power Sunroof
New Sound Deadening
Stock Rear End
AEM UEGO - $240 o.b.o (2000 km)
Blitz 80mm Nur Spec Cat-Back Exhaust (somewhat modded at cat start) - $550 o.b.o
Sparco Hub + Wheel - $340 o.b.o
Wire Harness - $500 o.b.o
Bings Tension Control Rods - $200 o.b.o
Overflow Tank - $100 o.b.o
Driveshaft - $400 o.b.o (Custom Made to mate with R154 Tranny to Q45 Diff)
P/S Cooler - $50 o.b.o
HKS DLI - $350 o.b.o (2000 km)
Custom Hydro Ebrake Setup - $250 o.b.o
20mm Wheel Spacers x 4 - $150 o.b.o
Wilwood Brake Proportioning Valve - $50 o.b.o
Apex’i Turbo Timer W/Harness - $80 o.b.o
Tach Box - $80 o.b.o
S14 Seibon Carbon Hood - $540 o.b.o
PM ME or email addy above
