All parts for a top-of-the-line 240sx/S13 conversion project must go!
Due to family emergency conversion project halted and everything is for sale at fraction of cost. Over 95% of items listed are brand new (w/receipts) and never used or installed.
See comprehensive list at the bottom of this post. Asking amounts specified in the list OBO. Looking for serious buyers only! Prefer to sell items in a group (ie intake+injectors, engine+fuel managment etc…). Buyers with intent of purchasing lager groups of parts will get a discount.
It is extremely important to me to sell these parts as quickly as possible!
Please contact:
- George at (905) 901-3054 (any time past 10 am) for more info or
- Peter at (905) 363-1002 ext:276 (9am-5pm) also email for pictures
eTrader@cogeco.ca
#) Item [purchase / asking $]
- Fully restored 1990 240SX coupe [1700 / 2500]
- 1998 SR20DET Black Top [4500 / 3375]
- 90 000 km (have dash from the clip)
- Compression tested 170+psi in all cylinders
- SR20DET wiring harness modified to fit 240sx [450 / 350]
- AEM fuel management system [2300 / 1800]
- AEM water temperature sensor [100 / 75]
- AEM 3.5 BAR pressure sensor [120 / 90]
- WELBRO Fuel pump (255LPH - up to 500HP) [180 / 140]
- 750ccm fuel injectors (x4) [950 / 600]
- FLEX-A-LITE dual electric fans + controller [398 / 300]
- KOYO aluminum radiator with Hyper Cap [422 / 340]
- GRREDY aluminum intercooler KIT [1036 / 777]
- GREDDY knock-off high flow racing AL intake [360 / 240]
- GREDDY knockoff aluminum high volume oil pan [230 / 173]
- Boost Controler (manual) [85 / 64]
- APEXI 3" Exhaust w/5" tip [650 / 488]
- mandrell bent stainless steel, 1 piece
- APEXI 3" stainless downpipe [250 / 160]
- APEXI 3" stainless elbow [75 / 56]
- TEIN front & back fully adjustable coilovers [1611 / 1208]
- TEIN tie & raduis rods [736 / 552]
- NISSAN 240sx 89-94 S13 outer tie rods
- NISSAN 240sx 89-94 S13 inner tie rods
- CFB Front & rear strut bars [320 / 240]
- 89-94 240sx TANABE Swaybars [657 / 420]
- Front (30.4 mm) & rear (22.0 mm)
- NISSAN 300ZX 90-96 braided brake lines [122 / 92]
- BREMBO Brake rotors [480 / 360]
- 13" BREMBO front and 11" rear rotors
- modified to fit 4 bolt pattern"
- 300ZX TT calipers (front & rear 4 piston) [590 / 443]
- 5 lug conversion rear hub [na / 400]
- Turbo universal insulation kit [90 / 68]
- ADX 18" (8.0" wide) aluminum rims w/NEXEN tires [1700 /1275]
- 255x35 ZR18 (rear) & 225x40 ZR18 (front)
- Z32 NISSAN Mass Airflow Sensor [450 / 300]
- Master cylinder [170 / 128]
- 1990 NISSAN 240sx control arms (front & rear) [500 / 375]
- JDM S13/S14 SR20DET Power Transistor chip (240sx) [500 / 375]
- BATTLE version adjustable rear suspension replacement [1050 / 788]
- 2x Red/Black Racing Seats for Nissan 240sx S13/S14 [400 / 300]
- 240sx front bumper [450 / 338]
- single piece aluminum drive shaft [700 / 500]
- Aluminum steering bushing [30 / 20]
- NISMO Engine & transmission mounts [230 / 173]
- SANCO radiator hoses [160 / 100]
- HKS boost dependent fuel pressure regulator [120 / 90]
- HKS racing blow-off valve [480 / 200]
- Racing steering wheel with quick release hub [180 / 135]
- NIPPOTENSO iridium plugs [100 / 75]
- 1998 RB25DET [1500 / 1125]
- Wolf 3D v4.0 Fuel Management [2100 / 1575]
- 3" Steel down-pipe [na / 80]
- TIEN front adjustable camber plates with hime joints [na / call]
- 240sx modified Xmember to fit RB25/26 motor [na / call]
- with engine & tranny mounts
- Stock Sylvia intercooler and piping [na / 240]
- 3" stainless test pipe [ na / 80]
- Rebuild 240sx gas tank [na / 200]
- Rebuild 240sx steering rack [na / 200]
- 240sx front bumper cover with opening for intercooler [na / 300]
- 240sx clear cover front turning indicators [na / 100]
- Hyperground grounding system [na / 100]
- Racing fuel cell (plastic foam filled) [na / 200]
- Stainless steel muffler (used) [na / 50]
- 1992 NISSAN 300ZX coupe for parts [na / 1500]
- QX45 80mm throttle body [na / 250]
So I will not be able to respond to the questions posted here untill I get back sometime after 6pm. However please call my brother, he is home the entire day! I will try to get a website up with all the pics, in the mean time you can email me and I’ll send some pics. Any serious buyers should call my brother ASAP after 10am. Again the phone # is (905) 901-3054.
