2002 Subaru Impreza Wagon 2.5TS
Ok i will be selling this car as a shell with clean title.
its a rolling shell, 95% of the exterior is there except for headlights
the interior is pretty much complete except for missing 1 front headrest and no radio
everything is still intact.
Car has 230k miles
automatic
was in running condition with no check engine light until the engine bent some valve.
Just want this thing gone.
No exhaust.
currently as it sit the motor is in the trunk and a transmission with a cracked differential is also included.
i will included the motor and transmission for another $400. let me know thanks
here is my phone number you can also text me 716 903 6606 David
Now on to some pictures.
so when you say you’re selling the motor and it has bent valves…I then assume it comes with the heads and intake manifold and TB? If so, I wants it.
Sorry I should of been more specific, $50 for the bottom end, $50 for heads. If you want complete motor with all sensor, its $200 but you need to pull it as I don’t have any tools to do the motor pull pm me if you wanna go over the details.
what about the AC idler pulley/assembly.
$20 and its in good condition pulley bearing still good.
Nice, i’ll take it then, but i want to make sure it will work with my svx (i just need the pulley/bearing)…from what ive read so far it should but i wanna double check…
you say trans w cracked diff so I’m assuming you’re talking about the front diff in the trans, correct? you know for a fact the diff is cracked? as in its been apart & checked out?
Yes 100% the differential is crack and yes front differential case. As it leaked through crack. It can probably be re welded.
