$7000 O.B.O 116,000 miles
Purchased from West Herr summer of 2005 with 34k. The truck has a Black interior with factory vinyl floor. 60/40 cloth bench seat, no jumpseats in the back.
1000 miles on new pads and new rotors
5000 miles on new drums, new shoes, new parking brake cables, and new shocks all around
5000 miles on new Yokohama Geolander AT
Front and rear diff fluid changed at 110k Open Front and Rear 4.10 factory gears
Plugs and wires replaced with Motorcraft parts at 105k
Drivers power window motor replaced at 110k
4wd works perfectly, clutch holds well, front end is tight and aligned.
Some rust around the wheel wells
ABS light is on because the sensors are pulling away from the tone rings up front
Transmission is hard shifting when cold, smooth when warm
A couple bulbs are out on the left side of the cluster
[ATTACH=CONFIG]22598[/ATTACH][ATTACH=CONFIG]22600[/ATTACH][ATTACH=CONFIG]22596[/ATTACH][ATTACH=CONFIG]22599[/ATTACH][ATTACH=CONFIG]22597[/ATTACH]
