Nissan Silvia/240 USDM Race prepared Drift machine.
Coupe chassis, Silvia Conversion, welded reinforced, caged (10-point) repainted inside and out interior black, exterior mettalic GREEN!!!, wide body front and rear, d1 drift kit, brick lights, v-mount set-up, custom dash with Carbon fiber panels, all switches and relays ready to go, Deep dish NRG Steering and Carbon quick release, Autometer tach, oil temp, oil pressure, water temp, boost and volt. All switches aluminate and master kill switch.
Suspension and Links:
Cusco rear coil overs
Tein Front coil overs w/ camber plates
rear Battle version camber arms and lower arms
front and rear suspension techniques sway bars and urethane bushings
Tein hard tie rods in/out
solid rear subframe bushings
Bakes:
300ZX all around, new stainless lines, and hard lines, new master, new front discs (brembo)
Custom Hydrolic e-brake, line lock and bias all with stainless lines.
5-bolt front and rear with rear 1" spacers
Advanti 18-8" wheels 2 sets.
Koyo custom for V-mount rad and custom dual intercoler (depending on motor set up.
hood pins
FUEL SURGE TANK
Master kill switch, aluminum battery box, window safety nets and sparco seat rails
HALTECH PLATINUM STANDALONE
CAR CAN COME WIH THIS FRESH VQ35HR 2007 350z MOTOR OR AS ROLLER (NO MOTOR)
AS IS $12,500
ROLLER LOADED READY TO DROP YOUR MOTOR $7,000
PM PLEASE
GLWS
