-S13sr black top( Red valve cover) runs perfectly fine
-Tomei Pon Cams
-Plug and play wiring harness for s13, cleaned up with all useless bs deleted
-E5 ecu(chipped and dyno tuned by RS Tuning) @13psi
-Tranny with new tail shaft seal, oem release bearing
-Fresh JDM non abs drive shaft(solid 2 piece, no rubber dampener)
-Gt28r- 6000km
-Adjustable waste gate actuator
-550cc DeatschWerks injectors (1000km)
-S15 oem gaskets (highest quality) 6000km new locking tabs as well
-N62 MAFS
-SS turbo lines
-Tomei rocker arm stoppers
-Stance clocking plates
-Freddy oil pan
-New water pump
-Newer Belts
-euro drive clutch, capable of holding 500hp(1000km)
-NISMO lightweight flywheel
-3" megan turbo elbow
-3" downpipe
-3" catback(n1 style)
-peak performance solid tranny mount
-hockey puck engine mounts or stock
-may have forgotten some other parts!
Engine is still in vehicle, runs and drives perfectly fine, come by for a rip if interested. looking to get $3500
647-894-6220 Nate text me for pics of engine or dyno sheet!
located in missisauga, delivery is possible!
Will Part it all out if the engine is bought de-modded!
I can remove parts to make it cheaper, ie: re- install the stock cams, stock clutch/ flywheels, remove turbo setup and injectors!
Let me know what you want!
