Figure its getting into winter and people are going to be wanting to do projects/new motors soon. I have a bunch of good cores, or use as is stuff.
6 bolt:
2 long block Motors that were pulled running. Both have over 100k miles on them and i would AT LEAST suggest re-ring/cleaning them but if you need something you can get away with running them as is. 1 motor has a 6 bolt head, the other has a 7 bolt head with the stud holes bored out to accept the larger bolts. no water pipes, sensors, or valve covers come with.
7 bolt:
4 Heads.
2 are complete with valves, springs, and cams
2 are missing cams
3 blocks
1x 99 block with thrust washer, stock bore never decked
2x 95-97 block bored .020 over
1x Crank. Spun bearing and will need to be ground. this may change, as i am dropping a bunch of stuff off at a machine shop and might have this done now
7 bolt 2.4L
I REALLY dont want to sell this, but if the price is right I will and go a different route.
This is a complete running motor that was pulled from a spyder and was just stock rebuilt. My plans now are to do a stroker build in another 2.0l block i have, but nothing is set in stone yet.
As for prices, make me an offer. I love trades too btw. so any parts, electronics, project cars, whatever…let me know chances are ill take ya up on the offer.
Also if you want a motor built or anything done, let me know and i can get together whatever setup you want.
Send me a PM if you want anything. My number is 7163435166, but…i am fucking terrible at responding to people and i for some reason forget my phone exists. I do not have my phone on my if i am in the garage, or doing anything other than sitting or sometimes in class and i do not text and drive. so if you text me and i dont get back to you immediately or even the same day please dont take it personally…unf its me
