just looking to see if I can find a set of used calipers and brackets before I go to the parts store and just buy new stuff. if you have anything available let me know.
thanks
-John
thanks
-John
I actually will have calipers and rotors in great shape for sale soon. I’ll come up with a price today. How much are you looking to spend?
well I was checking out prices at work today and the caliper brackets I can get new for $20 a piece, and calipers I can get for $40 a piece, the caliper cores are $25, so $30 for each caliper?
Hmm that seems kind if cheap. I have 45,000 mile rear calipers in great shape with new pads and slotted rotors from ssbc. Do you need rotors too?
I think I have all my rear brakes too. I know were the rotors, and Ebrake parts are.
Rest is in a box I’ll have to dig them up if you need them.
Yeah do tell where. That sounds very cheap. Usually the calipers with brackets are around $75-$80 and the core are around $80 also. The GM backing plates/brackets are around $70 each also
I work at advance Auto, looking through the computer we have the caliper brackets for '98-02 f-bods for $23 each, part number 14-1121, '93-97 calipers are $56 each with a $25 core, part numbers 18-4540, and 18-4541. '98-'02 calipers are $48 each with a $30 core part numbers 18-4696 and 18-4697. I guess I did round my numbers a little bit but I get a 20% discount.
hmm actually I was just on the advance auto website looking through parts and the brackets aren’t listed on the catalog. I’ll have to double check everything tomorrow.
So with no core you have $156 + tax for remanufactured parts for calipers alone. I have great quality oem brakes with low mile HP pads and rotors. If you make me a reasonable offer we can make it happen, but for $30 each I’ll keep them around.
I have other calipers I can return as cores, it doesn’t matter if it’s the right caliper I just have to return a caliper.
i could use a front set up if anyone has a set
I just have my stock rear rotors with 50K painted with VHT black, and the LS1 Ebrake shoes. forgot I traded my stock calipers, brakets and backing plates for the $800 rear race brakes. ya LS1 rear calipers and brackets people look for.
I have a LT1 setup on a 10bolt, might get getting another LS1 rear
i’ll keep you posted as i’ve been debating doing the front brakes to shave more rotating weight.
me too with the 3rd gen spindles, mad weight
How 3rd gen spindles only have a lower control arm, and no upper arm?
:snky:
