I need a 5speed manual transmission and the clutch assembly kit and the ecu for it 2 what yourr best offer
fail
ahh
I believe the OP is saying he/she needs the following:
- 5 speed transmission
- clutch assembly (pedal, lines, master and slave cylinder)
- ECU (i hope you know you can use the AUTO ECU with no issues)
I have a 2002 subaru WRX tranny but its misisng second gear i can get u a used flywheel and cutch too if u need but i dunno aobut the ECU u might have to wire one up out of popsicle sticks?
lol
ugh, welcome to SON.
I have a KADE trans in good shape with an RB20 bell housing on it and an RB shifter pot inside. 50…take it. Swap shit over. Or I can give you the RB O.E shifter as well. Drill a hole. away you go. Hit a junk yard for hard lines, slave, CMC etc etc.
i got sr trannys
i got a unknown ka trans lool. seriously, its unknown.
