Im looking for any parts towards a 5speed swap for my ka24e
PM if any luck
Got a seiko aftermarket clutch with 60% life left and a ka tranny with 200,000 km on it (no grinds) grab both for $120
I’ll even throw in a clutch slave
If you want… I can give you whole swap, csc, cmc, clutch, shifter, tranny, pedal, brake pedal, mount everything minus the hardlines for $250 OBO. Best way to get me is 416 930-0265, names Chris by the way.
PM’d
Thanks!
Just as an idea for what youre getting ill write it down here so you know what else you may need:
Tranny Xmember
Seiko Clutch (60% life)
Seiko Pressure-plate with bolts
OEM Flywheel with bolts (may need to be resurfaced)
CMC (if I feel it’s in good enough condition)
Tranny with 200xxx km on it (no grinds)
CSC
Manual Brake Pedal
Clutch Pedal
basically everything you need for the swap minus the hard lines.
Hope to see you Saturday.
Thanks alot,
Chris.
Oh edit: might also be able to throw in a manual ecu if you want.
i have a 5 speed transmission for a KA24DE
100$ picked up.
mission speed sensor everything elese works great.
PM if you want it!
i got a 5 speed tranny ka24de - $100
also got a used oem exedy clutch , pressure plate and Flywheel - $50
