I bought a motor for the block, so I am selling everything I don’t need off it. All parts are off a 2002 LQ4 6.0 out of a Silverado 2500HD. Mileage is unknown, but the motor was running when removed, and all parts are fairly clean. All prices do not include shipping or paypal fees. If you would like some pictures of a specific item let me know. I am fairly negotiable on this stuff, make a reasonable offer and we can work something out! I am located outside Buffalo NY 14086.
Accessories/misc.
Flexplate with crank spacer -$50
Truck oil pan with oil pickup tube - $40
Truck water pump - $40
Truck power steering pump bracket - $20
Truck intake with fuel rail, injectors, and DBW throttle body - $150
OEM LS valve covers - $40
Truck coils (8x) - $140
I have another 4x truck coils (heat sink style) - $70
Front coolant crossover line - $20
317 aluminum heads. One of the heads is completely stock, unmilled, and in great shape. No broken exhaust bolts. Comes fully assembled (valves, springs, etc). The other head has been shaved .024" and has some significant damage to the #3 combustion chamber, as it had a valve let go and bounce around in there when a valve spring broke. The rest of the head is fine and would make for a good practice unit for porting, or if you wanted to bolt a manifold to it for welding. I’d like to get $80 for the good 317, and $40 for the bad one.
Internal parts:
Valley cover - $20
Rear cover with gasket and rear main seal (used) - $40
Front timing cover with gasket and crank seal (used) -$40
Stock LQ4 crank - it has heavy scoring on the rod and main journals, since a few bearings spun. Make offer
8x LQ4 dished pistons and rods - press fit wrist pin style - no scoring or damage. Have some carbon buildup - $160
Also have 6x LQ4 dished pistons and rods from another motor, in good used condition, from another motor. $120
