Ok ,well I picked this up in October. Was built by a previous owner in 2007 pretty much. I am changing the set up due to a shit turbo. As well as needing some more work here and there .The shell has about 250k on it with rust just starting…
Engine
D16y8 swap… 15k on new rebuild
Made 260hp/217tq on 16lbs
450cc RC injectors
ACT 6 Puck Clutch
GT28R
Log style Manifold
Cobb Job Downpipe… welds leaked bad !
3 Inch Exhaust w/o test pipe
Tuned on Crome
Broken Radio
SRP Pistons 75.5mm/9:1
ARP Studs
Eagle rods
Walbro 255 fuel pump
HKS SSQ
TurboSmart Wastegate
TurboSmart Dual Stage Boost Controller
Godspeed Intercooler
Suspension shit
Omni Power control arms
Omni Power adjustable coilovers
Hx Rims
Goodridge Stainless brake lines
Rear disc conversion
Interior
DA seats
Full interior/carpet
Blox Boost Gauge
Blox Oil Psi Guage
AEM Wideband
Short Shifter
Probably misssing more …
Since I got the car in October '09 Ive done…
Synapse Downpipe
Remade Lower charge piping/dumptube @ Synapse
Goodridge Stainless Brake lines
RC 750cc injectors
Rear/Front brake pads/rotors
Exhaust manifold gasket
New Radio
Dizzy
Turbo XS Boost Controller
Deck … Joe Giggs Built
TiAL 38mm Wastegate
New Plugs( BK7’s)
Winter Snows and Winter Rims
Royal Purple Oil every 3k
Short Shifter
Alternator
GT3071R
ATP fittings/clamps
V -Band Conversion from the original 5 bolt design.
AEM Wideband
Greddy Type R BOV
AEM DRY FLOW FILTER
Dynomax vt muffler
Neptune RTP
Energy Suspension Shifter Bushings
New Trans ( Si)
Dyno’d @ 283 hp on 16lbs
Ran 13.6 @ 112 with a 2.5 60’
Ran 12.6 @ 112 with a 1.9 60’ on slicks after the retune @ 305 hp.
Soon Will be tuned with …
Comp Cam’s Race Cam
Zex Valve Springs
Cam Gear
Ported Head
Ported z6 head
Cometic headgasket
… DID IT WAS AN EPIC FAIL …
Spring '11
Spoolin Proformance Ram Horn
Spoolin 3" downpipe
All new Coolant lines
Retune on pump/race gas
Sell car …
Thanks to all SHIFT members that helped me along the way and continue to do so
I want this set up to make 300-350 wheel . I am not looking for crazy power here,just a fun DD with a college student budget . It was a big jump from going to a leather heated seat Volkwagen to a 92 civic. But its way easier to work on and it does not have nearly as many problems with it as the dub did when I bought it .
Future Plans…
Paint
Shell
If I keep the D series …
Motor Mounts
If not …
B- Series
Pics…
