'93 240SX Coupe, SR, with Silvia Front
1993 Nissan 240SX Coupe
S13 Silvia front conversion triple projector
97,000km from Hawaii (all documentation)
100% rust free, and solid
Engine:
SR20DET Red Top with 150PSI in all cylinders
GTiR T-28 turbo with S14 impeller and .86 turbine (Herman @ Cherry Turbo)
stainless steel feed and drain lines for the turbo
ISIS screamer pipe installed, also have aftermarket 3” downpipe available
full stainless steel 3” exhaust with Apexi muffler
Mishimoto catch can with Moroso exhaust evacuation valves
Tomei rocker arm stoppers (RAS)
480cc injectors
Aeromotive adjustable fuel pressure regulator with gauge under hood
RS-Enthalpy ECU with custom tune
OEM Nissan Z32 turbo mass air flow sensor
HKS adjustable waste gate
HKS SSQV blow off valve
Greddy knock off intake manifold
tube and fin front mount intercooler
Drivetrain:
ACT 6 puck sprung clutch
ACT Xtreme pressure plate
stainless steel slave cylinder line
Nismo pivot ball for clutch fork
Nismo slave cylinder
Nismo shift knob
5 Speed, NO GRINDS
DIF solid rear sub frame Bushings
Nismo front power brace (available, not installed yet)
Tein Super Street adjustable coilovers
S14 VLSD differential
Wheels, Tires, Brakes
16 X 8 “Euro X” Japanese 3 piece rims
205/55R16 General Exclaim UHP Tires
Infinity Q45 front calipers, and rotors with Hawk brake pads
OEM rear calipers and rotors with Hawk brake pads
stainless steel brake lines front and rear (available, not installed)
Interior:
aftermarket deck, and front and rear speakers with tweeters
S14 front seats
AEM wideband UEGO gauge
Apexi EGT gauge (needs new probe)
Apexi boost gauge
Apexi controller for gauges
HKS turbo timer
Red Top Optima battery located in the trunk
battery cut-off kill switch on the rear of the car
aftermarket 3 spoke steering wheel, also have OEM if wanted
The Bad:
needs a spray if you’re into shiny paint
missing the center lower foam inside the driver’s seat, can be replaced easily if needed
Asking for $7,200OBO
Contact Rick at 705-665-8600, or rick_anderson13@hotmail.com
My Kijiji add with pics here. I don’t have an account to host pics, sorry.
NO TIRE KICKERS, NO TEST PILOTS, NO TRADES, BE REASONABLE
Car is sold.
this was a very good deal for someone.
