98 Grand Am 2.4L Part Out: Supercharger, CF Hood, Much Much More
The parts that are universal to any car, not just a 96 - 98 grand am and / or a 2.4L LD9 engine, say Universal in the description, all others should be considered applicable to the car / engine
ALL ITEMS ARE OFFERS ONLY!!!
I have decided given the economic times, and rarity of some parts I will let all of you decide what you think the item is worth. PLEASE do not email me asking “whats the lowest you’ll take”, email me with serious offers, if i find them within reason i will tell you its sold. If get more than one offer on an item, highest offer takes it (and I WILL let lower offers know what the highest is so they wil have an oppurtunity to offer a higher price if they are so inclined)
I know how much this stuff is worth so please no BS offers like 50 bucks for the hood or something like that…
THANKS FOR LOOKING!!!
Feel free to email me at poppinfre5h@aim.com or text me at 607-377-0932. (i dont answer calls from numbers I dont recognize)
GM M45 Supercharger kit (everything needed to install this kit on a 96 - 98 including smaller starter)
also included is 2 quick change hub adapters a 2.6" and 2.5" pulley
NOT included - cruise control relocation backet
ECU with Custom Tune From HPTuners Including:
-Removal Of Speed Limiter
-Redline Raised To 6600rpm
-Rev Limiter Raised To 6800rpm
-Power Enrichment Mode Moved From 3400rpm to 2500rpm
-Spark Timing Was Decreased
-All VE (Volumetric Efficiency) Or Fuel Tables Were Smoothed And Tweaked
-Fans Were Set To Come On Sooner
-Open Loop ECT Was Modified
-TPS Power Enrichment Was Modified
-All Torque Management Was Removed
-Knock Sensor Sensitivity Was Turned Down Slightly To Eliminate Phantom Knock
Since this ecu already has credits on it for HPTuners that would save anyone 100 bucks, you would still need to get re-tuned based on what you have done to your application, but it already has a base tune done to it based on the current setup, so for example if you bought my entire setup and installed this ecu, you could start running immedietely, and i hit a 14.9 on sreet tires
Pacesetter Headers cut and welded to fit 96 - 98 Grand Am
Car-tec High Flow Catalytic Converter (its literally an empty shell)
2.25" Custom Catback Dual Exhaust with Borla ProXS Mufflers
Ford Brown Top Fuel Injectors (370cc)
Fuel Rail With Adjustable Fuel Pressure Regulator And Fuel Pressure Gauge
Warm Ram Air Inake made for the 2.3L Quad 4
Throttle Body Spacer
KYB GR-2 Gas Filled Struts, Shocks, and Eibach Pro-Kit Lowering Springs
Energy Suspension Poly-urethane sway bar End Links
RActive Front Upper Strut Tower Bar
A/C Bypass Pulley
17" Sport Maxx Racing wheels (missing 2 center caps) in OK condition
Universal 5 Lug 5x100 and 5x114.3
2 Good Tires On Back Rims (Aurora H107 245/45/17’s) Bad Tires on Front Wheels
JSP America Carbon Fiber Hood With Working Hood Pins (pins have some surface rust)
Tinted Tail Lights With VHT Nightshade
Universal 9006 HID 5000K Low Beam Headlight Kit
JDM Style All Black Racing Seats on 98 GA Slider Brackets
Pair of Universal 4 Point Harneses
Universal JDM Style Cross Floor Bar
Dual Gauge Pod Used Made for mustangs that supposedly fit the apillar of a 96 - 98
Universal 2 1/16" Autometer Carbon Fiber Air Fuel Ratio Gauge
Universal 2 1/16" Autometer Carbon Fiber Boost Gauge
Universal In Dash DVD Head Unit With 4" Screen
Universal 2 Universal 7.5" Sunvisor DVD Screens
Universal PLX Wideand Air Fuel Sensor Module and Digital Gauge (Used for about 2 months… PROBLEM, it only reads in Lambda mode)
Chrome Polished 2.4L IDI Cover (COMPLETELY POLISHED)
Pics:
by the way, the part thats yellow on the harness is black on the drivers side
I know these look dark BUT, i passed inspection with these on the car
with the reverse lights on
