Hey just wonder what i need to do to get a/c in my 240 ive been hearing different things from different people. I heard i need 2 get “custom a/c lines” ???
but have no clue on where i can get em from just wondering how everyone else does it. just cant take this damn heat.
use your KA ac compressor and use a custom bracket (big spacer basically) to mount it onto the SR. I think only one bolt doesn’t match up to the SR block… search 240sxforums, and you’ll see the kind of spacer/bracket people made to make it sit properly. That was your AC lines will thread in nicely and all you have to do is fill it with gas…
zilvia.net someone was selling the custom brackets before…
see the brackets that the AC mount is mounted to? that’s something you have to custom make. its not all that difficult
If you have the SR bracket, just trace the hole locations onto 2 separate flat bar pieces, mount them onto the block, then you need 3 people.
1 to hold the AC condenser, 1 to hold 2 straight edges, and one to punch the hole locations onto the custom made brackets when everything is in correct location.
