Closing on on the end.
1500#/ 200hp / 6 forward speeds / 12,000rpms / NA
Setting up Alignment!
See many more of the build here:
Ill be street beating before snow!
Excellent job guys, it looks great seeing it all together
“6 forward speeds” well your fucked if you ever have to back up without help.
Guess youve never heard of a six speed
I believe they put a busa motor and trans in the car. If thats what they did then no it doesn’t have reverse, but if I remember correctly it’s suppose to be a race car. Either way don’t mind :skid
yes it is the Busa motor and trans.
At 1500# I’d hardly need help pushing it backwards.
:ahh
point taken. weighs less then a mazda 626 and i’ve pushed one of those fairly quicky
any plans for busa turbo kit?
okay cool , but whats up with the rear wheel sticking out so much .
sure is, but we have to find out which links are weak and work up from there.
goal would be from 275hp to 325… easy to do with a busa motor
stance for stability is one reason the other is because i cannot find a wheel with enough offset to inset them some more…
we should have shortened the rear end about 2" on each side…that would have fixed the issue…
i like the poke!
a wide body kit would be sick then you can shove what ever wheels you want in there
I agree. But it would have to be a one off built by hand.
Perhaps Mike and Kevin from CRC would be the guys!!
DC
PISS OUT MY ASS!!!
Toss a set of fender flares on it. Did you guys keep it FWD?
As for reverse, most buggy guys use a flywheel attached to the rear carrier and a starter motor. Put the engine in Neutral and the starter motor backs you up.
No we changed it to RWD using a 1980 toyota corolla rear. built the tunnel and the driveshaft. slip yoke with a carrier bearing.
see entire build here… SonaBusa Build Pics
^ pics?
This really is awsome should make a hell of a track car esp with that wide ass. Is it coil or leaf rear?
I am very interested at how you made this rwd with the engine trans setup
