STM Rear Drag Brake Kits for Evo VIII-IX allow you to ditch the weight of your big, heavy Brembos and rotors and clears room to run smaller wheels and slicks.
This brake set-up is specifically designed for Drag Racing.
This is not intended for constant, on/off braking as in road-racing or autocross.
The scalloped rotor is 1.95 pounds lighter than the standard rotor and is recommended for cars that see more miles on the drag strip than on the street. The scalloped rotor is not a street rotor.
STM Rear Drag Brake Kit Includes:
- Wilwood Dynapro Single Calipers
- Wilwood Brake Pads
- Choice of Wilwood Rotor (Standard or Scalloped)
- Black Anodized Hat Color (Please call for custom colors)
- STM Brake Lines
- Aluminum Mounting Brackets
- Mounting Hardware
We ship orders with the black rotor hats. If you would like custom colors, generally it will take 2-4 weeks.
Replacement brake pads can be found HERE
Standard Rotor Brake Kit Specs:
Total weight per side: 10.65 pounds (Rotor, Caliper, Hardware, Line)
Rotor assembly only: 7.25 pounds
Scalloped Rotor Brake Kit Specs:
Total weight per side: 8.70 pounds (Rotor, Caliper, Hardware, Line)
Rotor assembly only: 5.30 pounds
Stock Evo Rear Rotor: 14.6 pounds.
Stock Evo Rear Caliper: TBA
Important Notes!
You will need to remove the E-Brake.
STM Staging Brake Kits are available. -
These brakes are designed for off-road use only and drag racing applications. They are NOT intended for consecutive, hard braking. These are not for road racing or autocross or daily street use. While these are also the same brakes we run on our STM 8 second cars, as with anything performance-oriented, please be sure to check and double-check every aspect for safety.
