Location - Beamsville
Condition - used
Contact - pm me or email him at
Posting this for my friend please pm me if you have any questions.
2x 12’’ alpine type r subs like new in the alpine box and a new alpine m1000 with random cap. for sale need to sell asap nice set up really loud pad $3000 for it all
asking $1800 for it all
specs:
Alpine Type-R SWR-1242D 12 inch Car Subwoofer
Features:
Peak Power Handling 1500 Watt
Nominal Power Handling 500 Watt
Frequency Respond 24 Hz - 500 Hz
Sensitivity 87 dB
Impedance 4 ohm
Specifications
High Excursion Tapered Half-Roll Surround
Aluminum Coated Dust Cap
Mirrored Progressive with Perimeter Venting
Frequency Response: 26Hz 1kHz
Dual Voice Coil Design
Extra Rigid Steel Frame
Heavy-Duty 8GA Push Terminals
amp specs:
Alpine MRPM1000, Mono Channel Class-D Amplifier (1900W)
Power up your system with Alpine’s V-Power amplifiers. These amps provide outstanding power output, flexibility and value with a bold, stylish design.
Amp Features:
Terminal Layout: Two-Sided
Screw Mount / Wire Cover: Integrated Wire and Mounting Screw Terminals
Amplifier Type: Class-D (Digital)
Channel Design: 1 Channel (Mono)
Thermal Control: Thermal Management Control
Power Supply: DC-DC PWM Power Supply
Power Supply Design: MOSFET Power
Board Circuitry: STAR Circuitry
Current Protection: Over-Current, Over-Voltage and Thermal Protection
Power Indicator: Top Mounted Blue LED Power Indicator
RCA Output: Gold Plated RCA Input Connectors
Speaker Level Inputs
Crossover: Adjustable Low-Pass
Connector Plating: Gold Plated Input, Output, Power and Speaker Terminals
Board Design: Dual Sided Glass Epoxy PC Board
Gain Control: Continuously Adjustable Gain Control
Amp Specifications:
Total Max Power: 1900W
RMS Power Ratings:
Per channel into 4 Ohms: (@ 14.4V +-1%THD+N, 20Hz - 200Hz) 600W x 1
Per channel into 2 Ohms: (@ 14.4V +-1%THD+N, 20Hz - 200Hz) 1000W x 1
Sound Tuning:
Crossover: 50Hz-200Hz, -24dB/oct. (Low-Pass)
EQ (Equalizer): Bass EQ (Fixed Frequency): 50Hz 0 to +12dB
Subsonic Filter: 15Hz (Fixed), -24dB/oct.
Dimensions:
Foot Print (WxHxD) mm: 380mm x 60mm x 242mm
Heat Sink (WxHxD) mm: 320mm x 60mm x 242mm
General:
Power Requirements: 14.4V DC (11V to 16V)
Input Sensitivity: 0.2 - 4.0V
Frequency Response: 20 -200Hz (200Hz/-3dB)
Speaker Impedance: 4 or 2 Ohms
Signal to Noise: 100dBA
pictures will be up later
