Just bought this for a computer I was working on, turns out the computer itself was toasted. This was turned on for a total of about 20 minutes, so it’s practically brand new. I did however remove the barcode for a mail-in rebate. The PSU is only a couple weeks old so I’m asking $40 obo.
SPECS:
Model
Brand
Antec
Model
EA-380D Green
Series
EarthWatts Green
Spec
Type
ATX12V v2.3 / EPS12V
Maximum Power
380W Continuous power
Fans
80mm low noise cooling fan
PFC
Active
Main Connector
20+4Pin
+12V Rails
2
PCI-Express Connector
1 x 6-Pin
SATA Power Connector
5
SLI
No
CrossFire
No
Energy-Efficient
80 PLUS BRONZE Certified
Over Voltage Protection
Yes
Input Voltage
100 - 240 V
Input Frequency Range
47 - 63 Hz
Output
+3.3V@20A, +5V@20A, +12V1@17A, +12V2@15A, -12V@0.8A, +5VSB@2.5A
Approvals
UL, CUL, FCC, TUV, CE, CB, C-tick, CCC, BSMI
Dimensions
3.4" x 5.9" x 5.5"
Weight
3.6 lbs.
Features
Connectors
1 x Main connector (20+4Pin)
1 x 4+4 Pin ATX/EPS 12V
4 x Peripheral
5 x SATA
1 x Floppy
1 x PCI-E
Features
No power cord included. By reusing your existing cord, you can reduce waste and help protect the environment
Over Current Protection
Manufacturer Warranty
Parts
3 years limited
Labor
3 years limited
