With today’s high-end parts using more power, (such as graphic cards or larger hard drives) this Ultra X-Connect ULT31554 ATX Power Supply comes in really handy. Its black case design features 500-watts of power, dual 80 mm fans, and supports Intel Pentium 4 and AMD motherboards. It also has a feature that helps keep the inside of your PC tidy. Unlike a regular power supply that has dangling cables, the Ultra X-Connect lets you plug in only those cables that you need; these cables even glow inside when used with UV lightning accessories! Add some muscle to your system and get this Ultra X-Connect ULT31554 power supply today!
Features/Specifications:
- Ultra X-Connect 500-Watt ATX Power Supply
- General Features:
- Black case w/ UV Green Fans - Light up your box!
- 500-watts
- Dual 80 mm fans
- 9 X-Connect cables
- UV ready cables
- Supports Intel Pentium 4 and AMD motherboards
- ATX ver 2.03 and ATX 12V ver 1.2 compliant
- Short-circuit Protection
- In-rush Current Protection
- Thermal Overload Protection
- Power Specifications:
- 115V, 230V switchable power supply
- +3.3V, 28A
- +5V, 30A
- +12V, 34A
- -12V, 0.8A
- -5V, 0.3A
- +5Vsb, 2.0A
- Unit Dimensions:
- 3.5 x 5.75 x 6-inches (H x W x D, approximate)
- Regulatory Approvals:
- UL
- FCC
- Retail Package Includes:
- User’s Manual
- One (1) 17.75inch 20-pin ATX power cable
- One (1) 17.75-inch 4-pin 12V power cable
- One (1) 17.75-inch 6-pin Auxiliary power cable
- One (1) 21.75-inch 4-pin power cable
- One (1) 17.75-inch 4-pin power cable
- One (1) 17.75-inch Y cable with floppy drive and (2) 4-pin power connectors
- Two (2) 17.75-inch Y cable with (2) 4-pin power connectors
- One (1) 6" Y-Cable with Two (2) SATA and 4-pin Power Adapter
- Power Cord
- Mounting screws
$50, new in box
